Reinforcement lengths
iluhi
In the project, the length of the reinforcement is like L=899, L= 1.71... is it possible to select 5 and its multiples while selecting the reinforcement from the program tabs? and think of the master who will cut this equipment.
I also think it is a problem that needs to be solved. Since the irons that are very close to each other in the footage do not resemble each other, it is very exposed.
In the newly designed beam/column vertical/wall vertical expansions in V6, the program adjusts the reinforcements to be multiples of 5 cm if the geometry is appropriate (as much as possible). This feature has not been added to the foundation and slab expansions yet. Which version are you using? Do you see such lengths in the beam/column drawings?
"iluhi":3cpw6cqx" said:
In the project, the length of the reinforcement is like L=899, L= 1.71... When selecting the reinforcement from the program tabs, can't multiples of 5 be selected? Also, consider the craftsman who will cut this reinforcement.[/quote ]
"eacikgoz":3cpw6cqx" said:
I think it is a problem that needs to be solved. Since the irons that are very close to each other in the quantity do not resemble each other, there is a lot of exposure.
In addition: Choosing the Diameter of the Ticker, Distance dimensions for the raft basic additional reinforcement .Immediate issues waiting for solution...
"Admin":1wpunli3" said:
In V6, in newly designed beam/column vertical/wall vertical expansions, the program adjusts the reinforcements to be multiples of 5 cm (as much as possible) if the geometry is suitable. This feature has not been added to the foundation and slab openings yet. Which version are you using? Do you see such lengths in the beam/column drawings?
I am using V7.015, you are right about the beam detail, there are multiples of 5 in additions, it adjusts the mounting and longitudinal iron according to the cover. We request from you that we can adjust the diameter of the reinforcement as we can adjust the height, if possible, we would be glad if you consider it in the new update, we are willing to make the necessary comparisons manually.
Can you mark the reinforcements that you expect to appear in multiples of 5 cm in column and curtain details, but which are fractional, on the project or screenshot, and give us an example?
