reinforcement is not placed on the jacketing in the retrofit project
kaenerji
hello, i am new to earthquake retrofitting project. I'm normally a 12-year-old ide-structure (static+architecture) user. but I had never done a retrofit project before. I am creating the project data according to the order of operations. I'm doing the calculation. but I can't get reinforcements in sheathing and reinforcement projects. help please.
"kaenerji":2gzcx1al" said:
hello, I'm new to earthquake retrofitting project. I'm normally a 12-year-old ide-structure (static+architecture) user. But I hadn't done a retrofitting project before. I'm creating the project data according to the process order. I'm doing the calculation. but sheathing and I can't get reinforcements in retrofit projects. help please.
Hello, After defining sheathing and reinforcement shears, you should do "Linear Performance" analysis after "Analysis + Reinforced Concrete". "Open Reinforcement in place" or "Open Reinforcement Outside" in the Drawing dialog while getting the column application plan If these do not solve your problem, if you send your project, we can review it.
