Reinforcement intervention to carrier elements
shewger
Only one operation is done on all similar carrier elements and the amount of reinforcement, diameter, etc. can be determined. Is it possible for you to change it? For post analysis. Thanks in advance for the replies, keep up the good work. Sent from my Redmi Note 8 Pro using Tapatalk
"shewger":2w26vn6g" said:
Would you allow me to change the amount of reinforcement, diameter etc. with just one operation on all similar carrier elements? For the post-analysis. Thanks in advance for the answers, good work. Sent from my Redmi Note 8 Pro using Tapatalk[/quote ] - In the menu that appears by pressing the right mouse button while on an object, you can specify certain properties with the "Select similar" command and you can select similar objects matching these properties at once. -In any reinforced concrete design dialog, using the "shift" and "ctrl" keys, you can select more than one line and thus you can change the dimensions, reinforcements and/or reinforcement fixing states of the selected elements at once. You can check the link "Did you know?(hint)" for using the commands.
