How can we increase the eaves length of only one surface on a 1-gable roof? I don't understand why there is no increase in the roof (create a gap) on the roof ) It would be great if it could be pulled by the roof edges or at the nodes. Best regards
sn ozguer, First of all, you can already select and pull the joint points of the roof you have created, that is, you can change the area covered by the roof in the plan in the direction you want. You can also stretch it in any direction and angle by selecting more than one joint point with the move joint point command. Changing the eaves distance of a single surface of the gable roof For this, click the roof command, select the change roof eaves properties command and click on the eaves you want to change. In the dialog that opens, you can increase the eaves distance to the desired distance. There are multiple methods to change the area covered by the roof in the plan. You can use them.
