Ramp-Arab
demir
LET HELLO COME EASY FIRST. AS SEEN IN THE RENDER, I CAN'T FIT THE CAR OBJECT ACCORDING TO THE SLOPE OF THE RAMP, I WOULD LIKE TO HELP.
Hello, You need to do this in the ideCADRender program. You need to throw the library object into the iderender program, rotate it in the ideCADRender program, and then transfer it to the ideCAD program. Take it easy, good work..
Hello, Just export the car and terrain to ideCAD Render. Switch to a view window that is suitable for rotating the car (front, right, rear and front view). Wipe the land. Then you can call the car by exporting 3ds, import 3ds into your ideCAD Architecture project, and call it as a library (ktp) in ideCAD Render or as a library into the architectural program. Take it easy, good work..
