raft foundation thickness
resesif_07
Hello. In my project, the raft foundation thickness is insufficient, I divided it into dilatations, what is the reason for the foundations that do not provide the thickness?
Hello. The thickness control depending on the opening can be intervened from the Calculation axles. Enter the Calculate axis edit command in the Slab toolbar and you can reduce the clear span value for the Thickness control for the horizontal and vertical axes of the RD11 and RD12 slabs.
"recessive_07":s14gz0f3" said:
I can't save it when I reduce it like this. Do you have any other solution suggestions?
For RD11 and RD12, if we look at the distance between two columns in a total of 4 axes, you can enter 1120cm spacing.
Hello there. Here is how we enter the value of clear opening for the thickness control. As a beginner, there is always a problem with mixing thickness because :(
