Raft basic calculation axle
"cesuray":1xr39i4y" said:
I am undecided about defining the axis of calculation, how should I define it? With the "change hanger geometry" command, the location and working distance of the reinforcement axis can be changed.
I want to determine the opening length and the reinforcement length, since it is a cross building, there are empty areas in the calculation axes in the picture, if I define a single direction in the project, it would be the correct definition as the raft is the foundation cross.
"cesuray":hp05wgxl" said:
I want to determine the aperture length and the reinforcement length, since it is a cross building, there are empty areas in the calculation axes in the picture, if I define one-way in the project, it would be the correct definition since the raft is the foundation cross for the calculation axles
You can determine it by dividing it by the tile edge.
