As Nedim said, it is not possible to answer your question as it is. Because the answer to your question lies in your carrier system. If your curtains are sufficient and they meet the alpha s requirement, we can say that your curtains should be normal ductile if your curtains are high ductile. = 6, you can not perform strong column and joint shear safety checks. If you do not have a shear wall, you will get r=8, your earthquake load affecting your system will decrease, but the ductility checks we have mentioned come into play. If you do not have a shear because you are in the 4th degree earthquake zone, the building's importance factor should be <1.4 and Hn You can take r=4 and solve the ductility level normal system provided that the floor system is <25m(Hn<13m if the flooring system is without gear, cassette and beams). So you can understand that we can choose according to your R abundant system. The program will guide you about the selection of the R coefficient anyway. Mr. Nedim, I'm wrong. If there is, please correct it... good work... KEMAL YALVAÇ
