Quantity and Cost
mimsta
Quantity reports should be detailed. For example, when calculating the basic mold, length X should be the height, not the width. It would be better if the details were given that a term called polygon is used in flooring. Quantities can be exported to excel. There should be an approximate cost table depending on the quantity. mold concrete iron quantities for the stairs should appear in the quantity reports. It would be much better if the quantities are detailed for those who prepare progress payment for the project. It would be great if you could add an image about how the metering reports look in the new version.
Quantities obtained as a result of reinforcement after reinforcement are also given. We request you to consider this important issue in terms of reinforcement cost :))
