Apocalpyse
Hello. Can you help with my questions below? 1) I want to group lovers and add skins to be able to load in the attached project. Is it possible? or should i do it with inter-element overlay command? 2) I wanted to make a purlin layout as in the attached figure. When I wanted to automatically add purlins between the first beam and the last beam, there were options perpendicular to the first object or perpendicular to the last object. For this reason, I had to make the lovers one by one. it will be on a slight slope on the roof, so it made me very tired in the elevations. Was there an easier way? 3) Is there a command to merge lovers or merge lovers groups? Thank you so much in advance. Good work.
