hebunyayik
I CAN'T CORRECT ERRORS IN GEOMETRIC CONTROL I'm NEW CAN YOU HELP? COLUMN GIVES BEAM INTERCEPTION FAULT I ATTEMPT 70/70 BEAM TO THE POLYGON COLUMN AND THE OTHER EDGE 60/70 GIVES ERROR ONLY GEOMETRIC CONTROL 70/70 I REMOVE THE BEAM 60/70 BUT ORAKONİŞE A LIQUIROME TRAVELER BUT HORAKONİŞTE A GEOMETRIC DRUM BILISIM, THE BEAM IS FIXED.
