Problem with curtain vertical openings
"yunussacikk":3ne6jygu" said:
this is how I copy it even though I copy it multiple times
Hello, Your question is not understood, can you elaborate what the problem is by adding your project?
In the screenshot I sent earlier, the reinforcement is not shown at the curtain ends. When I send it now, there is no vertical continuity in the reinforcements.. The column on the lower floor is smaller at the top, but there is no reinforcement continuity.
Hello, In the earthquake regulation, the size of the curtain head area is halved after the critical floor. In terms of reinforcement continuity, the header area can be made up to the critical floor header area in all floors. In the Reinforced Concrete / Curtain menu, the head area reinforcements can be made the same on all floors.
Isn't the vertical continuity of the reinforcements in the curtain caps a necessity? Shouldn't it do this automatically?
"yunussacikk":897wbeoa" said:
Isn't the vertical continuity of the reinforcements in the curtain headers a necessity? In Yasin's reply, you can see that the program offers you an additional option. You can do the same if you want.
