Problem in outing of raft's drawing
ammer
hello dears
I have created a raft foundation and i worked his analysis with no errors.but i got an issue when opening the results of reinforcement and it's drawing..here you are my file in the attaches....please guide me and do solve my work.....
thanks and with all my best wishes to all...
Hello Ammer,
ammer":36ookvv1 said:
I have created a raft foundation and i worked his analysis with no errors. But i got an issue when opening the results of reinforcement and it's drawing..here you are my file in the attaches....please guide me and do solve my work.....
There is an option named "Automatic building code application" in the analysis settings and unchecked in your project. Program is not reporting any errors because of that... If you check the option, you will see some errors while reporting as that screenshot I enclosed...
Some message occurs according to Turkish EQ Code 2007, some message occurs according to Turkish TS 500. You should decide to solve those problems or not according to your codes ...
"Vertical load is too high" messages : Those messages occur when Ndmax is high then 0.5.Ac.fck according to Turkish EQ Code. See "column normal forces" table in column reports...
"Punching security not satisfied" messages : Those messages occur according to Turkish EQ Code for raft foundation. See raft foundation reports...
This error is not connecting to any codes...
"Admissible ground stress exceed" messages : Your "Safety Admissible ground stress" is too low, 6 t/m2 in Analysis Settings. After raft foundation analysis, Maximum admissible ground stress is calculating as 20.76 t/m2. (20.76 > 6). See raft foundation reports...
hello dear hakan,
many thanks to your advises and clarifications,it was so clear.i will do,but i got a last question about idecad,
Although there are an errors, but idecad extracted the drawing's Results,
why?
thank you again for your cooperation
why?
There is no reason to be not extracted the drawings... Drawings may be drafts, not final results. Besides, project may be reinforcement project and some errors may not be important.
Maybe I want to write the data of reinforcement results and make the drawings without making analyse etc.
