As of version 7 of the program, pool equipment and drawings are not calculated, static analysis of the pool is performed as a shell model under its own weight and hydrostatic loads. You can see the analysis results and reinforcement areas of your pool (in terms of the amount of reinforcement required per square meter) from the 3D analysis result section. You have to do the selection and drawing of the reinforcement.
