"cakilomer":3efzfl80" said:The direction of the project I have already drawn has changed, that is, the length of the sides of the building has changed by 50 60 cm. Is it possible to change it in the easiest way in the ide? In a way similar to the sc command in autocad? Good work.[/quote ] *If the direction of the structure has changed, the structure can be rotated at a certain angle with the Change/Rotate Structure command *If the distance between the axes has changed, the axes can be moved with the Move command.
