"fmwaral":2io0lmru" said:I wrote a message for the same problem this morning, but I can't find the problem even though I did what was said.
"emrebagdu":2io0lmru" said:I added the project, thank you again if you check it out.[/ quote] The data of both projects are currently under review. After detecting the problem, we will report the solution. Thank you...
Your project is on the 1st basement floor K20 -A small piece of beam has formed in the junctions of K250-K220 beams. (Same situation exists on other floors) If the misalignment of the K220 beam is drawn as defined from the bottom and connected to the joint point at the intersection of the K220-K250 beams, this small piece of beam does not form. The beam joints mentioned in the example project were made in this way and analysis can be done. Good work"emrebagdu":3impndtf" said:mrb, while I was solving my project, I encountered an error called "pivot error in matrix reduction" under the heading "The system cannot be resolved in analysis", what does it mean? How can I fix it, I would be glad to help. Good work
I fixed the stair braces and R coefficients. The solved project is attached. Ünver ÖZCAN"mozyaylaz":29j80ljt" said:teacher hello, when I analyze my project, I get a pivot error, and when I do geometric control, there is no problem. I request your help on the subject
Please add your project."eatac69":2tycbev7" said:hello, I'm having the same problem, I would appreciate your help
Hello, there is information about the problematic joint in the Analysis screen and in the 3D screen. The problem is caused by the unsupported tile you defined on the wall object. If you delete this tile, the project can be analyzed Slabs are not solved together with the walls.Some notes about the project: -Model the elements P1 and P2 as two curtains using the curtain command, not as a polygon column, and define them as a group. On the curtains that do not provide the 1/6 dimension ratio within the group, the curtain features 'Short Tick 'title pitch'"semihocaktan":1phyk6go" said:I have the same problem, could you please check
