Perspective view gets dark
selcen
While working on the 3D floor plan, after the objects I brought with the block, a situation that we can call excessive shadowing or darkening in the perspective view occurred. I can't find the reason. please help...
Re: blackout in perspective view...HELP Hello, If such a blackout occurred without rendering, it may be related to your video card. If the problem persists, you can call our Istanbul office and get technical support with remote access. Take it easy, good work..
Re: darkening in perspective view...HELP Could there be a problem with the light I brought with the blocks? Thanks for your answer
Re: darkening in perspective view...HELP Hello, It may be possible if you added artificial light later. You can turn off the artificial lights from its layer and test whether it is caused by it.
