Although the basement basement curtains that do not continue on the upper floors share the shear force coming to the basement floor, it does not make sense to strengthen the basement curtains in the performance analysis. The high values in the basement walls in the calculations are the high earthquake load applied to the basement walls in accordance with the regulation with the new structure analysis logic. However, at the point where we reached a consensus with the teachers, the materials such as 2.5.2,3, 2.8.5, 3.5.2, which are prepared with the logic of new building design and in ductile structures, should not be applied to the basement curtains. Ide put an option for this in the analysis settings. However, due to the calculation method and their rigidity, high values may occur in the basement curtains. However, my advice is not to reinforce the basement curtains after solving the problems in the other elements of the structure. This pointless practice is difficult and increases the cost, and as a result you will spend a significant amount of money, but you will not make a positive contribution to the horizontal load capacity of the structure.
