Performance Analysis Crash Issue
desgilad
I get a crash error in performance analysis. There is no problem in solving the system or there is something I do not know. I would appreciate if you could help with the attached file.
In the project, the reinforcement corrosion factor and insufficient clamping length factor (0) and (0.4) are seen. Also; It would be appropriate to add the basement height to the ground floor height and define it as a single floor. In order for the reinforcements not to change, the reinforcements should be fixed by marking the Ds columns in the Reinforced Concrete dialog. *In the attached example, the corrosion and yield stress multipliers were entered as 1. The basement floor was added to the ground floor. The performance level is life safety.
