Görkem2007
Hello, We need to draw roof eaves in a villa project we are doing. In addition, we need to make a small roof covering 96 cm below the roof eaves by giving an elevation of -96 cm on the same floor. We want the roof eaves, which you can see in the attached project, to rotate 360 degrees around the roof slab. We can do this with the slab edge, but in this case, it overlaps with the roof slab D36, which is given an elevation of -96 cm. It takes a piece of the lower slab and lifts it up. I think it is because of the intersection of the slab edge lines of two different slab elements. What can we do to fix this? Is it possible to give jeans to the floor edge lines? Or is it necessary to draw these records in a certain order? I wish you good work. Görkem Demircioğlu Civil Engineer Nicosia - TRNC
