Hello, I could not save the wind lovers in the attached project. In general, I would appreciate if you share your valuable opinions about the framework and combinations in the project. I wish everyone a good work.
Hello there; You have run your lovers on the weak axis, you should turn them 90 degrees and divide from all intersections with the divide command. When the analysis is done again, there is no problem.
