oblique axle
demir
HELLO, MY AXLES ARE OVERLOAD BECAUSE THE DISTANCES ARE LOW, HOW DO I MAKE AN INCLUDED AXLE OR ANGLED AXLE THANKS.
Re: EGIK AKS Hello, if you explain the problem with a sample picture or within the project, we will understand the problem more clearly. Good work
Hello, I can suggest you to move the axle label as a solution for this situation. You can access the command with change/object edit/move axle/ax tag and change the location of the axle tag. Good work
The command to lengthen and shorten the axis line is "right delta, left delta" in the Axle settings dialog
