Object warning when tilting beams for ramp
zekaikc
When we slope the beams for the ramp in our project, there is such a warning in the geometric control, how can we fix it?
If you don't mind the architecture, delete the curtain on both beams. If you say no, move the upper beam by 3o cm, then lay a 30 cm console floor. However, in this case, a stud beam comes into the wrapping region. Maybe it can be solved from the program settings as well.
"zekaikc":33uzu6z0" said:
In our project, there is such a warning in the geometric control when we slope the beams for the ramp, how can we fix it?
Hello, you are getting this message because the left ends of the beams K100 and K101 overlap. In order not to receive the error message -overlapped object- in the geometry control and to get the reinforcement details of the K81-K100-K101 beams appropriately, change the view direction of the K101 beam with the "Determine Object Direction" command in the "Change" menu. drawn continuously with K80-K100 after editing. K101 is detailed separately. Note: Inclined slab error in geometry control is due to the connection of D77 slab slab to beam K100 at zero elevation. Delete beam -K100 so that inclined slab can be defined correctly. Level and right end values of beams K98 and K101 Enter as zero - Redefine the D77 tile - In the tiling assistant toolbar b With the -Bevel Objects- command, select the slab, beams K101 and K98 and make it sloped. -After this step, the view direction of K101 can be changed and the K100 beam at the floor level can be defined. Good work
"vforvendett4":1brqfor0" said:
if you don't mind the architecture, if you don't mind the architecture. If you don't mind the architecture, move the top beam by 3o cm and then throw a 30 cm console slab. However, in this case, a stud beam comes to the wrapping area. Maybe it can be solved in the program settings.
thanks for your reply
"Levent Özpak":35wwr3fj" said:
Hello, the left ends of the K100 and K101 beams You are getting this message because it conflicts. The beams are connected to the columns correctly and there is no problem in the analysis model. Change the view direction of the K101 beam with the "Set Object Direction" command in the "Change" menu in order not to receive the -object-overlapping error message in the geometry control and to get the reinforcement details of the K81-K100-K101 beams appropriately. After this arrangement, it is drawn continuously with the K80-K100. K101 is detailed separately. Note: The Inclined slab error in the geometry control is due to the connection of the D77 sloping slab to the K100 beam at zero elevation. Delete the beam -K100 so that the sloping slab can be correctly identified. Enter the elevation and right end values of the beams K98 and K101 as zero. -Redefine the D77 tile. -Collect the slab, K101 and K98 beams and make it curved with the -Bevel Objects- command in the tiling assistant toolbar. -After this step, the view direction of K101 can be changed and the K100 beam at the floor level can be defined. Good work
thank you, I did it as you said, good work
