fatihkaya17
I want to write because I see a problem in the support of the N76 joint point. There is no problem in the reinforcement of the column, but it attracts more moments than the other symmetry column. It will affect the center of rigidity and may cause malfunction in the system. I couldn't define a node myself. Actually, the reason why I write is only because I know that you can fix such problems with your review.
Log in or register now.
