Node error
Mairon
Hello, I am getting a nodal point error while analyzing the simple steel structure I have modeled. Even though I've done the geometry check and the overlap checks, there doesn't seem to be a problem. When I examined it on the 3D solid model, I couldn't find any problems again. Could you please have a look?
Is there anyone to help with this issue? What is the cause of the error? I've done all the checks and even redrawn from scratch. Column nodes are giving errors.
Hello there; If you examine your Analysis model from the Perspective screen, the error appears: 1- You have incorrectly formed cross-members that are not in the solid model, but delete them. 2- Since the beams on which the V braces sit are connected to the lower end of the column at zero elevation, no support has been formed under those columns, and if you define the support, the system is solved. The analyzable model is attached. Best regards.
"2m project":2rrb0wdk" said:
Hi; If you examine your Analysis model from the Perspective screen, the error shows up: 1- You have empty-end cross members that are not in the solid model but formed incorrectly, delete them. There is no support under those columns because it is connected to the columns, if you define the support, you will solve the problem. The analyzable model is attached. Regards.
Thank you. I will pay attention to the points you said. Thanks again for the analysis
