Hello. I am trying to learn ide7 demo. I delete the pleats in the tile tab of the reinforcement selection table for the pleated design in slabs. When solved, it finds reinforcement diameters like Q999. It fixes itself when you dissolve the pleat again. What is the problem?
Hi, For pileless design on slabs, you should select the reinforcement type of the reinforcement axes as "flat reinforcement at the top + bottom" with the "Reinforced Concrete Calculation Axis Edit" command.
