New Version let light features
onderyk
hello, new version is out. I love and enjoy working with 3d visuals more than architectural drawing in idearchitecture. Only if there is a library or toolbar with let light features in this new version, I will make my projects more beautiful in night rendering. This is my opinion, maybe there is, I don't know, but if there is such a feature, it will be great in new versions.
Re: New Version hello, I wish you could tell me a little bit about the links you sent, what I should do... also, dear admin, I want to make a vertical arch system around the french balconies in my render project. eg: we are making arch-shaped beams in the x direction, I want to do this in the y direction, but I couldn't.
Re: New Version Hello, Download the sample ies light source given in the link and copy the ies extension file or files you downloaded into the Photmetric folder in idecad Architecture. In this way, you can import IES light sources with different characteristics into the program. To create LED light, go to the material settings of the object and click the effects tab. You can give the LED light effect when you activate the glow feature and enter a value. Also, check the rendering user guide
With a clearer drawing of the arch question Or if you explain with a picture, I can help. Good work...
Re: New Version
"hatice":1sk5l2qg" said:
Hi, Download the sample ies light source given in the link and copy the ies extension file or files you downloaded into the Photmetric folder in idecad Architecture. You can import ies light sources with features into the program.To create LED light, go to the material settings of the object and click the effects tab, you can give the LED light effect when you activate the glow feature and enter a value. Also, check the render user manual
If you explain the question about the arch with a clearer drawing or image, I might be able to help. Good work...
Hatice hnm, thank you for your attention. By arch I mean it is usually done on balconies, mosques usually have many examples. I don't know if I could explain :) :roll:
