Re: NAMING After you have done your automatic naming, you can give the desired name to the object you want with the Change/Object edit/Object name command.
With automatic object naming, the name of the raft tile changes depending on the names of the floor tiles. Of course, the object can be changed with the edit, but I think I made a suggestion that the raft tile should be excluded from this naming . Another problem is the use of floor ids in flooring. For example, writing a text such as DB223 for a floor number 23 in the 2nd basement in an already small and cramped apartment causes the font size to decrease or the floor circle to enlarge. The formwork plan already expresses a certain floor. Therefore, this indexing can be ignored in the drawing. Column-beam-floor etc. in order to facilitate the formwork plan drawings of similar floors. I suggest that the subject of giving names independent of the floor should be considered.
