my first project. Do I have any mistake? can you help me.
Re: my first project. Do I have any mistake? Can you help Hi there is Column beam composition shear safety error in S34 and S35 Columns, Column beam composition shear safety errors are not listed in the error list on the first page when you receive the report, therefore, in the Report menu --> Earthquake Regulations --> Column Beam Composition Safety You need to do this check by taking the report The model does not seem to have a connection problem. No wall load on Basement Ceiling beams, No walls on ground floor? Please find attached the document on the solution of column beam composition safety problems.
Re: my first project. Do I have any mistake? can you help first of all thank you very much for your help.. it didn't give that error in my project. As you said, I looked at the earthquake regulation section and it did not give any problems. but since the size was not enough, I sent you the other floors. now it gives me the error you said after opening the deleted project and copying the fold. but it does not give such an error in my original project. I will add a new apartment entrance wall.
"ibrahim.ozuag":3rsolbff" said:
first of all thank you very much for your help.. it didn't give that error in my project. As you said, I checked the earthquake regulation section and it didn't cause any problems. I sent you delete floors. now after you open the deleted project and copy floors, it gives me the error you said. But it doesn't give me an error like that in my original project. I will add a new one to the apartment entrance wall. For this, you need to fix the system by taking advantage of the document I added in my previous message and taking into account the current architecture.
Re: my first project. Do I have any mistake? can you help Basement floor curtains should be marked as a panel that does not continue in flood/ all snow.
Re: my first project. Do I have any mistake? can you help friends, in my project it gives the error (ab) in columns and characters, how can I fix it, thank you.
Re: my first project. Do I have any mistake? can you help open the reinforced concrete-parameters-beam parameters, TDY Article 3.4.3.1 control will not be selected there.. You probably have this selected.
Re: my first project. Do I have any mistake? can you help friends, I made a foundation pile project for the first time in idecad, but I wonder how we will learn about the reinforcements, if you could help me I would love it??????????????????????????? ???? :?:
Re: my first project. Do I have any mistake? can you help friends, i'm pissed at the base, but does anyone know where to look for the equipment :???????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????
"static":s7qx0o4t" said:
friends, I'm sorry for the basics, but does anyone know where to look for their accessories? ??????
Get the pile reports from the Reports Menu You can find out the required reinforcement area in the "As" section of the Pile End Effects report.
Re: my first project. Do I have any mistake? can you help THE REPORT YOU SENT GIVES ND MD MD3 AS VALUES BUT THESE RESULTS ARE NOT INCLUDED IN MY REPORT WHY IS IT?????????
"static":yk01w1yc" said:
IN THE REPORT YOU SENT, THE ND MD MD3 AS VALUES HAVE BEEN GIVEN BUT THESE RESULTS ARE NOT INCLUDED IN MY REPORT WHY I wonder?????????
If you add your project, I can take a look.
Re: my first project. Do I have any mistake? Can you help Instead of the values you write in my pile reports, I have min. It writes reinforcement. How can we see the values in your report?
"haliltek":3n43p2ee" said:
In my pile reports, instead of your values, I write minimum reinforcement. This means that it is not forced and no reinforcement is required.
