I am trying to design a multi-storey reinforced concrete for the first time and the ground values are very low. Could you take a look at the project? What should I do? correct the errors, edit the --X direction R coefficient by getting Rx=8, D=3, A=11 from the wizard, --1 mark the basement floor outer bulkheads as basement bulkheads, select --4.9.1.3.a, [url =https://www.idecadsupport.com/forum/viewtopic.php?f=5&t=9577]viewtopic.php?f=5&t=9577[/url] --Column not carrying axial loads increase column size, --B errors Check the link below, My columns have warning B. How can I solve it?
--If these suggestions do not balance after making, add curtains, Ünver ÖZCAN
