Hello. In my project, when I copy the ground floor to the basement floor, the drawing does not appear in the plan. Is it because the drawings are too far from the zero point? Can you help me?
Hello, If you click the zoom drawing command after copying, the objects appear on the plan. However, before copying, you must move your drawing to the origin point. Note: The right slab edge of the D17 slab does not connect to the K03 beam.
