Modeling of a raft foundation with different upper elevations
uzooo
Good afternoon, in the attached project... the lower level of the foundation is at the same level... Due to architectural necessity, 50 CM RADGE IS REQUESTED BETWEEN THE FOUNDATION AND THE AXLE... There will be a -20 cm difference in the upper basic elevation. should it be? Is there any harm in doing it as in the attached project? Good luck with.
Hello, As in the attached project, 1 cm of the D axis. Create from the right. The analysis model will be formed correctly. Good work
