aksualigurbuz
take it easy everyone. I had a few questions. I would be very happy if I could get an answer. 1- What exactly does it mean to model curtains as shells. What happens if I do not model the panels as shell finite elements?.. What effects will occur? What will be the effect on the columns? (connecting columns) 2- In new building designs, do basement curtains also have shell finite elements? Will we model as elements? 3-Why do we model as shell finite elements? 4- In retrofit projects, will we model the curtains in the existing structure as a shell or without it? Why? 5-Are we going to model only the ones above the basement floor as shell finite elements among the existing[/b] in retrofit projects? Shall we model separately for the basement and upper floors (shell or normal) 6- In retrofit studies, we will model new rigid shears on the existing rigid shears? reinforcement curtains may come. In this case, should the existing rigid curtain be demolished and rebuilt, or should it be left as it is? If we are going to leave it, will the existing panel be considered as a shell? Or will the curtain (on the basement floor) that will be built instead be considered as a shell (new reinforcement curtain)? take it easy everyone. Maybe an answer you give will answer a few questions. It seems like I'm confused. Thank you...
