aksualigurbuz
take it easy. I wonder how can I combine two different projects. I want to do "copy with base point" like in autocad and add the elements to the other project. take it easy..
[ b]Copy to file[/b] save one of the projects (layers of course) to a separate file using the command paste from the file In this way, you can combine the two projects. (You should pay attention to the holding and placement points of course.) In this way, the project that will be formed separately (with dilatation) will have more than one rigid diaphragm. If it is not dilated, the project will be integrated by combining the beams in the common columns. Take it easy."aksualigurbuz":2aro3zoi" said:take it easy. I wonder how can I combine two different projects. I want to do "copy with base point" like in autocad and add the elements to the other project. Easy.
Hello, Unlike the normal version, in the demo, the possibilities of outputting, exporting and copying to a file are disabled. Therefore, you cannot combine projects because you cannot copy to a file in the demo."AbdullahK":kh2cw3q0" said:Can't we do this in the demo?
