masonry building
Can we define it as a beam on the wall or is there a difference when we define it as a beam? I designed the panels as masonry here and I put beams, is it a wrong application or is this what we call on-wall beam?
Hello
"mehmet2015":3f31wi65" said:
Can we define it as a wall beam or is there a difference when we define it as beams. I designed the panels as masonry here and I put beams, is it a wrong application or is this what we call on-wall beam?[/ quote] You can't have an account made and approved by approval authorities with such acceptances. If you look at the earthquake regulations, there are many places to check in the calculations of the masonry building. This program does not make these checks because it is written for reinforced concrete. If you can make this structure reinforced concrete, the program will prevent you from making mistakes by checking
