izmirli_35_35
After the analysis, when I look at the Curtain results from the Reinforced Concrete--> Curtain tab, I see that there are caps on the right and left of the curtains in the elevator curtains. 1- When I delete these head reinforcements and reduce the spacing of the longitudinal reinforcement in the middle, I get the required reinforcement area. CAN THAT BE A SOLUTION? WHAT IS THE DIFFERENCE? 2-Are we going to correct the number of longitudinal reinforcements in the right and left header here, just like the correction we make in the longitudinal reinforcement in the column when the right and left of the curtain is capped? If the number of reinforcements on a lower floor is low or the number of reinforcements is different...
