location problem
akiftekin
When defining a location, there is a problem where there are colons. What is the reason? When I remove the column, I can define the location, but when I put a colon, there is a problem. As in the appendix..thanks
Good work, it seems that the wall fragment in the marked area is under the column. I think the problem will be solved after deleting this part. If it is still not resolved, you can upload your project and we will examine it from there.
Hello, I am having the same problem. Since I cannot cross the zone line in places with columns, the zone cannot be defined. I have uploaded my file, please help.
It happens because you don't see the panel as a border object in your project. First, wipe all the space edges. Send all the walls to the background (the space is based on the panel under the walls) You can draw the edge of the space on the panel borders and create your space (do not draw the edge of the space on the column edges) Take it easy, good work..
Thanks for the answer Ms. Seda, but my problem continues, and when I made a "zoom drawing" on it, the location of the door windows was changed. Please help if there are different solutions.
Good work, we have carried out the operations that we conveyed to you in the project file. There does not appear to be a current problem at the moment.
