Location and section material list is a big problem
bartayd
dear teacher, while determining the location in the floor plan, I write the materials in the area as follows: tile: ceramic coating wall: ceramic coating tav:beyaz paint location exactly like this, but when taking the section, I want the material list to be as follows, respectively BATHROOM CERAMIC COATING LEVELING CONCRETE REINFORCED CONCRETE FLOOR CEILING PLASTER How can I write a section like that, thank you sir...
Re: LOCATION AND SECTION MATERIAL LIST BIG PROBLEM In your location settings; The list you write one under the other in the texts/ overlay name section is for plan display only. You can write wall, anneal etc., in short, you can write only parquet or leave this part blank. In the section, composite materials are taken into account, not what you write here. First, enter composite materials from the settings menu. Here, define a new material, the layers below which you want to see in the cross section. It is enough to do this process once for this compound material. When you save material, you will access this list from all your projects. Then select the areas you have drawn and enter their properties. Check the composite material from the general settings tab in the site settings dialog. At the end of the list you will see the material you have created. Exit by selecting it and saying ok. When you take a section, these layers will now be listed under the location name.
