layer menus?????????????????????
mimariproje
I wonder if there are only 2 layer menus in the program, are there any features such as closing the layers with a single button, reverting, isolating, etc.?
Hi, In the Settings menu layer settings dialog, there are commands to turn off / lock layers / Create and delete layers.
Thank you for your explanation, but this is not like that in other programs, it is only on a toolbar. I don't know if these features are open to self-criticism, but it would be great if work is done in new versions on this subject, and it will speed up the work.
"architecture":hre1ou6z" said:
thanks for your explanation, but this is not like that in other programs, it's only on a toolbar. I don't know if these features are open to self-criticism, but it would be great if work is done in new versions on this subject.
Layers Opening and locking operations can be done from the toolbar. The trap can be closed by clicking the X sign. The layer can be locked by clicking the lock sign. You can also use the "Close Object Layer" and "Lock Object Layer" commands in the menu that appears when you select the element and press the right button on it.
With idecad, you can close and lock individual layers. You can turn them off and on by clicking the signs next to the layer settings. Also, there are different application options such as all floors and active layers. I was a cad user before, but after I started idecad, I did more work in less time.
