Kindly need a pile project model
hello mr. miraly :D :D :D
thanks to your offer
i have a boring pile for example dia 35cm ,load pile capacity 500 ton and length 12m,soil bearing capacity 100 kn/m2
need
*how to calculate the value of the Ks bedding coeff.
* vertical spring factor kv
*where can i see for pile bearing check
if you modeled any project please share it here
Hi Ammer,
Idecad models piles with using the springs depending on the soil types. At this point, you must define the soil layers. So you need the soil survey report. If you dont have it, you should use general coeff. values for certain soil types. You can find it on internet. In this case, you need to know the soil layer's heights. Check the pic below. First layer must start the program ground level. If your foundations top under the program ground level, you need to add this extra height for H1. Define the soil layers using soil layer dialog box. Good luck :)
HELLO DEAR :D :D :D
if you please attach me any sample model for the pile including the soil property of the soil made by idecad...
thanks again
