It keeps giving basic error
gökerinsaat
Hello... We were using Ide-Static 7 before. We switched to Ide Statik 8 version. In the project I sent in the attachment, Ide Static 7 does not give any errors in the basics. When we start to solve the project with Ide static 8 version, the foundation beams give an error. I would like your help to fix the error. Thanks...
Re: continuous foundation error... Hello, In your project, rafter raft foundation system was chosen and superstructure interactive solution was made. This capability was added after version 8,504. It is not possible to compare the two models, as there is no possibility of an interactive solution with beamed raft foundations and superstructure in the 7th version. Starting from version 8.504, analysis methods of foundations have been developed. It may differ with older versions.
Re: constant foundation error... Thanks for your reply... Ide Statik 7 version also has superstructure interactive solution possibility. How can we solve the constant basic errors for the project we sent in the annex. Thanks....
Re: continuous foundation error... Hello, in ideCAD Static 7 version, the superstructure interactive solution option is only considered for raft foundation and continuous foundation solutions. The superstructure interaction solution for rafter raft foundations has been made as of version 8.504. When we make the following adjustments to your project in version 8.504, the soil tension problems are fixed. It becomes trouble-free when you amplify the TK8-9-10-11 foundations by 30 cm and when you increase the Tk12-13 foundations to 60 cm width. You can view the attached project.
