INTERVENTION IN THE STRIKE RANGE
zaferuu
Hello there; A FLOOR WILL BE ON THE EXISTING OLD BUILDING BUT THE STOCK RANGE OF THE COLUMNS OF THE OLD BUILDING IS 25cm IN X-RAY CAN WE INTERVENE IN THE STOCK IN THE IDE MODEL?
Hi, in the Column Reinforced Concrete dialog, the diameter and spacing of the stirrup reinforcement can be changed in the Transverse column. In addition, in the jacketing tab of the column properties, it can be defined whether there is stirrup compaction at the top and bottom ends of the column.
