civilmehmetkara
Regarding the connection of the column just behind the Closed Outer with the beam, is it mandatory to lay a beam of 25*36cm, considering the floor thickness here as 12cm? Is there any other solution other than discarding this very healthy beam that allows the outer frame to form?
