Integration of equipment
yunussacikk
HELLO When printing, reinforcement texts or dimensions can be nested. Although there is a place on the sheet, they are intertwined. The problem can be solved with the scale or font size, but the length of the blueprint is increasing. Can we prevent the reinforcement texts from being intertwined?
Hello, In the drawing you sent, the distance of the dimension text has been changed, if you change it to 1 cm as standard and draw again, the problems with the dimensioning will be fixed. The font and sizes seen in the drawing are not in the ideCAD Standard font settings. Compare your drawing settings with the font and heights in the "Black background" template. You can move overlapping texts and drawings with the "Quick move" facility without exploding the block by simply pressing "M" on the keyboard.
Yes. For example, if you copy the 1/25 beam expansions next to the 1/50 formwork plan drawing, you need to enlarge the beam expansion 2 times.
