Hello, Mr. Hakan. Can we use the base springs as an insulator? In the experiment I sent attached, I placed springs on the column bases, but there was no change in the construction periods.
You must define your dampening apple. You can enter the unit of the final element in ton sec / meter. Also, it's okay to define it as a spring. but my end element doesn't work either. I reported this situation to ideYAPI. They said they will fix it in version 6.0100.
