Hüseyin Yalçın
		Log in or register now.
 idecad version 10.20 raft gives the problem of lack of basic reinforcement. Do you have any solution? Thank you from nowHello, In your project; - Basement curtains It is not modeled as a shell. It would be appropriate to model it as a shell. -Rat nets do not form under some columns at the top and bottom of the building. In the attached example, all walls are modeled as shells. The raft boundaries have been recreated. In the reinforcement selection dialog, 18″ reinforcement diameter is selected for the additional raft reinforcements and the reinforcement is reinforced. problem solved. Good work"Hüseyin Yalçın":2lfrrtee" said:https://we.tl/t-GW2fRmKOa2 idecad version 10.20 raft gives the problem of insufficient basic reinforcement, do you have any solution? Thank you in advance
