Insufficient foundation in steel building
baris1234
Hello. When I analyze my 2-storey steel project, I only get the error that the cross section is insufficient. I made a 50cm foundation and got an error. Even though I made it 5 meters thick, I still got the error of insufficient cross-section. I'm sharing the model, I'd appreciate it if you could check it out. download link =>
Re: insufficient foundation in steel building Hello; For the reinforced concrete raft foundation design, the calculation axes should be arranged in both directions according to the distance between the columns. You are having problems with the minimum thickness control. While the foundation is selected, enter the right button - slab reinforced concrete calculation axis edit option. As you can see in the image in the window that opens, edit the distances to be used in the thickness control. No insufficiency is observed after the analysis. In your project, an arrangement has been made as 600 cm for the x direction and 400 cm for the y direction. Good work.
