sonsamuray
hello, I am getting the error of insufficient reinforcement in a slab in the system. Is there a problem with the nodes of the system?
Log in or register now.
Hello, the required reinforcement area cannot be met according to the selected reinforcement diameter in the left support of the reinforcement axis of the D40 slab 2. If you select larger reinforcement diameters for the slab additional reinforcements from the reinforcement selection dialog and analyze, AS (-) problem is solved. Good work"sonsamuray":u54e4d1i" said:hello, I am getting the error of insufficient reinforcement in a slab in the system. Is there a problem with the nodes of the system?You do not have permission to view link Log in or register now.
Thank you"unver":1xtol4b2" said:Hello, have the flooring reinforcements selected from the reinforcement selection Q10 and analyzed, it does not give an error Unver ÖZCAN
Thank you very much"Levent Özpak":1kljgm97" said:Hello. area cannot be met according to the selected reinforcement diameter. If you select larger reinforcement diameters for Slab additional reinforcements from the reinforcement selection dialog and analyze, the AS(-) problem is solved. Good work"sonsamuray":1kljgm97" said:hello, I am getting an insufficient reinforcement error for a slab in the system. Is there a problem with the nodes of the system?You do not have permission to view link Log in or register now.
Hello There are two reasons for the insufficient raft base reinforcement: First, it is necessary for the raft foundation The main reinforcement area is not sufficient with the selected raft foundation diameters and spacings. In the program, the raft foundation rebars are determined according to the rebar diameters you have selected and the rebar spacings determined by the parameters. Choosing a larger rebar diameter may be a solution. Second, although the raft foundation main rebars are sufficient, the diameter of the additional rebars and spacings do not provide the required reinforcement area. The solution to this problem can only be achieved by intervening in the diameters and spacings of the additional reinforcement.You can follow the status of the raft foundation reinforcement reinforcements in the Raft Reinforced Concrete dialog from the "Moment-Reinforcement Areas" and Additional reinforcements tabs."mesutkoku":bajiwk0o" said:I get the error of insufficient reinforcement in the raft tile, but the error does not disappear even though I change it manually. What could be the problem?
