colakoglum
Good Day, Although I reduced the analysis errors in the system to 3 in the attached file, the number of errors increased after I opened the shutdown. I wonder if I'm making a mistake. Thank you for your interest.
It is written specifically per version information, just in case you continue to have problems. If you continue to have problems, you should provide information about what you did in the step so that we can create the same scenario for technical support Write to the portal."nurgulkaya":1wusi7wu" said:Hi; V10.20 version does not have such a problem. Your project has been modified, the number of errors has been reduced, and it is saved and reopened. The number of errors continues to appear. Be sure to save it. If you wish, save it with another name as a backup and try it. Good work.
