Incorrect column panel placement
hızırex
Dear official; I am getting column panel placement error in the attached file. Is there a way I can place the column and panel like this? I do not have a chance to make the nodal points of the columns and curtains in the same place because the colored panel and the upper panel do not work on the same axis. I am waiting for your help. Good work.. Thank you..
Hi, Check the Analysis pattern. If the wall and column connection in the analysis model is made correctly and you do not have a problem when you receive the drawing, you can ignore the error in the Geometry control. You need to model the nodes of both curtains in the column. If you add your project, we can review it.
Dear Yasin Tezel; Our project is attached. Two errors in the geometry control have not been resolved yet. I hope you can help, and we are also curious about your comments for the project in general. Good work.. thanks...
If you define the axis of the panel shown in the picture and the following panels as centered, the connection error will be corrected as the nodal point of the panel will remain in the column. Columns are defined on the elements defined by the panel object up to the ground floor in your project. You cannot draw a column on the panel. Lower the existing column to the foundation. You can define the growing part of the section with the panel.
